Author Topic: FS:ESS Profile NVG. Revision Desert Locust google  (Read 2138 times)
Offline Speed Light
« on: April 27, 2008, 06:15:58 AM »
What I got here is a set of ESS Profile NVG and Desert Locust google that came with everything including the sleeve protector and the two lens. There's no scratch on the lens whatsoever and I am only asking for $30.00 shipped for the ESS Profile NVG. Also I have a Revison Desert Locust google system that came with everything including the polarized lens and the sleeve protector. I am only asking for $80.00 shipped or both for $100.00 shipped and insured. Postal MO preferred and if you have any question please ask me. Thank you.
ESS Profile NVG
Designed as the ultimate protective eyewear, the Desert Locust Goggle builds
upon Revision Eyewear�s unmatched ability to protect soldier�s eyes. The Desert
Locust combines the best ballistic protection with a perfect facial and helmet
fit, balancing the soldier�s need for comfort with well-sealed eye protection.
The high performance OcuMax™ coating prevents fogging and scratching to
ensure clear vision while the optically correct goggle lens is engineered
to maximize field-of-view and provide unprecedented visual clarity.
THE DESERT LOCUST GOGGLE SYSTEM
• HIGH-IMPACT One-piece, optical grade polycarbonate lens shields eyes from
PROTECTION unexpected fragments
• CLEAR VISION High performance OcuMax™ coating protects against fogging and
scratching. Top & lateral forced air vents provide constant airflow.
Filtration media prevents small particle entry
• FIELD-OF-VIEW Widest field-of-view to enhance war fighting capabilities
• DURABILITY Superior anti-scratch hard coating; designed for use in extreme climatic
conditions. Resists a wide variety of chemicals
• COMFORT & FIT Lightweight and comfortable, the Desert Locust is ideal for both tactical
operations and extended-use missions. Pliable frame material and
strapping system seals the face while maximizing facial comfort
• COMPATIBILITY Low profile design ensures compatibility with helmet, binoculars and
night vision systems
• ADJUSTABILITY Adjustable strapping system fits over the helmet, or on head, under hat
• LENSES 100% protection from harmful UV-A, UV-B and UV-C rays. Optically
correct lenses can be interchanged quickly for various light conditions
• PRESCRIPTION READY Optional Rx insert is also compatible with Revision Sawfly® Spectacles. Revision offers Rx Carrier fulfillment services.
See www.revisioneyewear.com for details
« Last Edit: April 28, 2008, 06:28:49 AM by Speed Light »
