SJH155D search light, adopting H1 vehicle bulb as light source with focus reflector, may control the light to search on Up, Down, Left and Right position through remote controller, and operate under attaching to the roof of vehicle as strong magnetic bottom, it is available for operation to insert power supply plug into vehicle cigarette plug. Streamline design, and adsorb to the roof of vehicle as normal drive. Adopting high luminous flux bulb, long lifetime, super focus effect, farther shooting range. Rotate horizontally without the dead point but circular motion. Through remote controller, startup the light and search revolving on the vertical & horizontal direction, and it is available to remote control within 30M.Adopting high penetrability PC material as shell, the surface hardness to 3H as the strong surface-painting treatment, ensure hard to fade color and scratch, supreme full-sealing waterproof performance and defend efficiently the rainstorm attack.
Technical Data
Model SJH155D vehicle searching light
Rated Current 4.5A
Horizontal Rotary Angle 360 Degree
Horizotal Rotary Speed 38 Degree/ S
Light Flux 1550Lm
Remote Frequency 315Mhz
Weight 1.47kg
Rated Voltage 12V
Rated Power 55W
Vertical Rotary Angle 210 Degree
Vertical Rotary Speed 44 Degree/S
Lighting Angle FOCUS +2(-2) Degree
Remote Distance 30M
