Author Topic: 5 D cell mag  (Read 19161 times)
Offline knot
5 D cell mag
« on: September 30, 2007, 01:43:09 AM »
I bought a 5D cell maglight for $3.00 at goodwill. I then bought a garrety xenon bulb for a 4D flashlight. I am disappointed. I am not impressed with the output/ Garrety must suck I imagine.
« Last Edit: September 30, 2007, 01:49:34 AM by knot »
| B e d a  z z LED | ||'""|""\___
| _____________ l ||__|_|___|
Re: 5 D cell mag
« Reply #1 on: October 01, 2007, 03:23:38 AM »
Hey, but that ain't half bad for three bucks!  :thumbup:
« Last Edit: November 10, 2007, 04:59:35 AM by regentag »
Offline knot
Re: 5 D cell mag
« Reply #2 on: October 01, 2007, 05:45:16 AM »
From what I've read, there is a radio shack bulb that is very bright when overdriven. This 4 cell garrity bulb in a 5 cell light isn't.
Offline knot
Re: 5 D cell mag
« Reply #3 on: October 03, 2007, 04:04:45 AM »
It was dirty and getting only 4.? Volts. It's not as yelllow now but I'm not blown away like some people and their CR123 2C MagMod and bulb
Re: 5 D cell mag
« Reply #4 on: October 19, 2007, 04:55:58 PM »
I may not remember this correctly, but I believe if you run a 4 cell "Magnum Star" or whatever Mag's halogen bulb is called (not the krypton) with 5 D NiMHs, that's supposed to work out well.
One of the keys to D cell lights whether LED or incan, is to run NiMH's.  The output is relatively flat (without a regulation circuit) and  they run forever!  Still, other than maybe a 2 D, they're clumsy as hell, just the same.  Hey, I have a 4 D 32 LED m@g!  :D
Offline knot
Re: 5 D cell mag
« Reply #5 on: October 21, 2007, 02:58:12 AM »
Thanks Dave.  :thumbup:
Offline jimjones3630
  • Better to light one light than curse the darkness!
Re: 5 D cell mag
« Reply #6 on: November 10, 2007, 04:48:58 AM »
5 D mag will fit 4 emoli cells=16.8v and run a 64623 like a dog.
FS sf M3, emolis & A123s
Aspherical lens for incandescent flash lights
Offline knot
Re: 5 D cell mag
« Reply #7 on: November 10, 2007, 06:20:49 AM »
Yeah but won't I have to spend a hundred dollars on a ceramic bi-pin holder to hold the bulb - and metal reflector?
Re: 5 D cell mag
« Reply #8 on: November 10, 2007, 07:29:27 AM »
that may have been true at one time. Certainly was what I understood.
Northern Lights has been researching and developing a soon to be released bipin G6.35 adaptor.  Have been fortunate to received some of his bi-pins for testing and evaluation.
thermal imaging studies show heat patterns and have a fair idea of what is needed for heat management with extreme, 200w+, incan. mods.  With use of fairly reasonable priced ceramic bat insulation bi-pin adaptor, of course the higher resistance in the circuit the higher heat production so all the usual and couple of not so know resistance fixs make a difference plastic pedistals are not melting with 200w+.
So yes to metal reflector, have ordered some from new manufacture about $14 shipped, will follow up with report.
jim
Offline knot
Re: 5 D cell mag
« Reply #9 on: November 10, 2007, 07:40:13 AM »
What about ceramic bi-pin holders that are common for 12v halogen bulbs. Can they be made to fit onto the maglight switch assembly?
Re: 5 D cell mag
« Reply #10 on: November 10, 2007, 11:39:43 AM »
Yes - they can and have been made - most notably by Fivemega, Maglight pimper extraordinarie.
It's a very nice "drop-in" ceramic and nickel plated brass holder for the W/A series of bulbs.
They are probably "out there" if you look.  About $30 IIRC.
Cheers,
Re: 5 D cell mag
« Reply #11 on: November 10, 2007, 09:20:19 PM »
Yes FM makes bi-pin g4 sockets, he does not make g6.35 size which is needed for Osram bulbs
No one makes G6.35pin bi-pin drop in sockets available to the public that I know.  If you do please let me know.
There are ceramic G6.35 pig tailed sockets, have not used them.  Northern Lights bi-pin sockets have less resistance than FM's as tested by me.
I suppose one could used a pair of alligator clips and tape to the pedistal and would work. Having a ciruit that shows effiency and knowledge of electronics is the Art part of electronics as opposed to putting together a bunch of parts.  Mods showing high efficency of 0.4v or less difference between vbat and vbulb tells the story for me.
« Last Edit: November 10, 2007, 09:31:49 PM by jimjones3630 »
Offline knot
Re: 5 D cell mag
« Reply #12 on: November 10, 2007, 09:29:15 PM »
Maybe I should have worded that, "can I make a bi-pin socket, out of those common ceramic bi-bin sockets for 12v halogen bulbs, from ordinary hand held tools?" If the pins don't line up or are too thin, can't they be modified by adding length and bending?
« Last Edit: November 10, 2007, 09:31:10 PM by knot »
Re: 5 D cell mag
« Reply #13 on: November 10, 2007, 09:33:10 PM »
Yes I think you could. can you post your vbat, and vbulb results?
Offline knot
Re: 5 D cell mag
« Reply #14 on: November 10, 2007, 09:35:26 PM »
Sorry, I don't have a bulb nor the ceramic bi-pin at this time. I do, however, have a potential host.
Why would I care if there is a .27v difference? It would be hella bright as it is and i'm not entering any lumen olympics competition.
« Last Edit: November 10, 2007, 09:38:49 PM by knot »
