Author Topic: Peak Product Line  (Read 3591 times)
Peak Product Line
« on: September 14, 2007, 01:10:58 PM »
This is a lengthy and rather dry document, but it does give some helpful information.  Pictures will be posted soon, but in the meantime feel free to check out the website: www.peakledsolutions.net
PEAK LED SOLUTIONS PRODUCT LINE SEPTEMBER 2007
The Peak product line of LED flashlights has established a reputation for innovation, reliability, quality and overall lasting value.
Designed, manufactured, and hand assembled in Phoenix, Arizona, U.S.A. by a company established in 1975 to produce Aero-Space and Electronic products, the Peak line of LED flashlights is unequaled.  No other flashlight company can offer a more extensive line of custom and semi-custom quality pocket sized LED flashlights than Peak LED Solutions, at non-custom competitive prices.
• All mechanical components are CNC machined from aircraft grade Aluminum, solid Brass, Stainless Steel, or of limited runs of Titanium.
• Unique modular designs
• Different optional body styles within the same flashlight line.
• Different battery sizes: AAA, N, AA, CR-2, CR-123A, LR-44, RCR-123, LIR10180, LIR10280, LIR17650, LIR18650, A-123 to meet any   requirement.
• Different battery types: Alkaline, Lithium, NiMH rechargeable, or Lithium-Ion rechargeable.
• Different finishes: Anodized Aluminum or 24 carat Gold plated Brass.
• Laser engraved logos or company names.
• Different candlepower output power levels.
• Different accessories: momentary switches, adapter clamps, colored light wands, bicycle handlebar clips and weapons mounts.
• Peak LED Solutions exclusive “Snow” white 5 mm LEDs for unequaled true color reproduction.
• All white LEDs are specially hand picked for maximum light output and natural color reproduction.
• Different color LEDs including Ultra-Violet, Red, Amber,  Blue, and Pink-Violet.
• The Peak LED Solutions one of a kind Custom Shop that can modify our standard products.
• Peak LED Solutions can create and contract manufacture special application LED flashlights for other companies.
PRODUCT LINE OVERVIEW:
• MATTERHORN: AAA battery 1 or 3 each 5 mm LEDs
• FUJIYAMA: 2 x AAA battery 1 or 3 each 5 mm LEDs
• SHASTA:  N cell battery 1 or 3 each 5 mm LEDs
• KILIMANJARO: AA battery 1 or 7 each 5 mm LEDs
• McKINLEY: CR123 battery 1 or 7 each 5 mm LEDs
• BALTIC SEA: AAA or N or LR44 battery 1 watt LED output
• PACIFIC: AAA or AA or CR2 battery 1½ watt LED output
• KINO BAY: AA battery 1 watt LED output
• GLACIER BAY: CR123 battery 1 watt LED output
• ATLANTIC: CR123 battery 1½ watt LED output
• CARIBBEAN: CR123 battery: 1½ watt LED output
• MEDITERRANEAN: CR123 battery 2 watt LED output
• RAINIER: RCR123 battery 3½ watt LED output
• MAUNA LOA:  CR123 battery 5 watt LED output
• VESUVIUS: RCR123 battery 9 watt output 3 LEDs
• LAW ENFORCEMENT FLASHLIGHTS
MOUNTAIN SERIES
MATTERHORN:  The Matterhorn is a small pocket LED flashlight that uses a single AAA size battery and one or three 5 mm LEDs.  It is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass and in limited runs of Titanium. Three different power levels, High Power single LED head, (34 candlepower) High Power three LED head, (90 candlepower) and Ultra Power three LED head (120 candlepower).  Battery compartments include Key Ring, Lug, and Pocket styles in black Anodized Aluminum, Brass, Stainless Steel and Gold plated brass.  Battery compartments of Key Ring and Pocket styles in Stainless Steel and limited runs of Key Ring style in Titanium are available. The pocket body with the optional cap can be used as a spare battery/storage compartment.
The Matterhorn can use Alkaline, Lithium or NiMH rechargeable batteries or 3.7-volt Lithium-Ion rechargeable batteries.  Two different sized special AAA Lithium-Ion rechargeable batteries, (10280 and 10180), and charger is also available with a 5/8 inch or 1 inch shorter battery compartment. The special sized AAA Lithium-Ion options, (standard output or high power only), makes the Matterhorn the first true high performance key-ring flashlight available anywhere. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
FUJIYAMA: A special battery compartment that uses two AAA batteries in black Anodized Aluminum or Stainless Steel and in limited runs of Titanium is called the Fujiyama.  Two power levels are available, a High Power (40 candlepower) single LED or a High Power (110 candlepower) three LED head.  There is no light output decrease over the life of the batteries. With a pocket clip and a momentary switch, the Fujiyama flashlight was designed for use by medical personnel or as a handy shirt pocket flashlight. The Fujiyama can use Alkaline, Lithium or NiMH rechargeable batteries. The Fujiyama head may also be used on the Matterhorn bodies. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
SHASTA:   The Shasta is a small pocket LED flashlight that uses one or two N size battery(s) and one or three 5 mm LEDs.  It is available in black Anodized Aluminum, Brass, and Gold plated brass. Three different power levels: High Power (34 candlepower) single LED head, High Power (90 candlepower) three LED head, and Ultra Power (120 candlepower) three LED head.  Battery compartments include Key Ring and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass.  There are also black Anodized Aluminum or Brass bodies that use two N cells. And black Anodized Aluminum and Brass bodies that have a different independent head on each end or one end can be used as spare battery/storage compartment with an optional cap. The pocket body with the optional cap can be used as a spare battery/storage compartment. The Shasta can use Alkaline, Lithium or NiMH rechargeable batteries or 3.7-volt Lithium-Ion rechargeable batteries in single cell operation only.   An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The Shasta head may also be used on any of the Baltic Sea bodies.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
KILIMANJARO:  The Kilimanjaro is a small pocket LED flashlight that uses a single AA size battery and one or seven 5 mm LEDs.  It is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass. Three different power levels: High Power (34 candlepower) and Ultra power (40 candlepower) single LED head, and a High Power (190 candlepower) seven LED head.  Battery compartments include Key Ring, and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass and of Key Ring in Stainless Steel are available.  The pocket body with the optional cap can be used as a spare battery/storage compartment. The Kilimanjaro can use Alkaline, Lithium or NiMH rechargeable AA batteries or 3.7-volt Lithium-Ion rechargeable batteries. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
McKINLEY:  The McKinley is a small pocket LED flashlight that uses a single CR-123A Lithium battery and one or seven 5 mm LEDs.  It is available in black Anodized Aluminum, Brass, Stainless Steel and Gold plated brass. Three different power levels: Ultra Power (40 candlepower) single LED head, a High Power (190 candlepower) seven LED head and an Ultra Power (260 candlepower) seven LED head.  Battery compartments include Key Ring, and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass and of Key Ring in Stainless Steel are available. A double-ended battery compartment is also available that can use a different head on each end or one end can be used as a sealed spare battery/storage compartment with an optional cap. The pocket body with the optional cap can be used as a spare battery/storage compartment.   The McKinley uses 3 volt Lithium or 3.7-volt Lithium-Ion rechargeable batteries. A 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
OCEAN SERIES
BALTIC SEA:  Is a new design for 2006 that incorporates the latest in battery management electronics and a high performance 3 watt LED. The BALTIC SEA electronics monitors the requirement of the power output of the LED and the ability of a single Alkaline battery to supply electrical current to maintain that output level.  When that output level can no longer be maintained, the electronics changes the operating mode to a battery saver operation by decreasing the output to about one-half of the original start up output.  Lithium and NiMH rechargeable batteries maintain constant power output until depleted.  The BALTIC SEA electronics can double the battery life at equal or greater light output in candlepower than some other same sized competitive LED flashlights.
The BALTIC SEA is a small compact and versatile LED flashlight that can be configured by the user to different requirements. The head is available in 5 different power output levels from 50 to 280 candlepower with Luxeon III LED, and from 80 to 400 candlepower with the Seoul P4 LED. The head can be moved between up to 9 different battery compartments.  When powered by 2 AAA or 2 N cell batteries, the output can range from 50 to 450 candlepower.  The BALTIC SEA is the most efficient/powerful LED flashlight in its size range currently available.  The 5 mm LED Shasta heads may also be used on the Baltic Sea battery compartments.  Battery compartments include Key Ring and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass and in limited runs of Titanium in key ring style. The pocket body with the optional cap can be used as a spare battery/storage compartment. There are also black Anodized Aluminum or Brass bodies that use two N cells, two AAA batteries or two LR-44 size button cells. A double-ended N cell battery compartment in anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap. The Stainless Steel version is available with single or two AAA batteries in the key ring style. The two AAA battery style with a momentary tail switch and pocket clip makes for an excellent one-handed medical inspection or shirt pocket light.  The BALTIC SEA can use Alkaline, Lithium or NiMH rechargeable batteries in AAA, N, S13 or LR44 sizes.  An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
PACIFIC:  Is a new design for 2006 that incorporates the latest in battery management electronics and a high performance 3 watt LED.  The PACIFIC electronics monitors the requirement of the power output of the LED and the ability of a single Alkaline battery to supply electrical current to maintain that output level.  When that output level can no longer be maintained, the electronics changes the operating mode to a battery saver operation by decreasing the output to about one-half of the original start up output.  Lithium and NiMH rechargeable batteries maintain constant power output until depleted. The PACIFIC electronics can more than double the battery life at equal or greater light output in candlepower than some other same sized competitive LED flashlights.
The PACIFIC is a small compact and versatile LED flashlight that can be configured by the user to different requirements. The head is available in 5 different power output levels from 50 to 400 candlepower with the Luxeon III LED, and from 80 to over 500 candlepower with the Seoul P4 LED. The head can be moved between up to 5 different battery compartments. When powered by 2 AAA batteries, the output can range from 50 to over 1000 candlepower. The PACIFIC is the most efficient/powerful LED flashlight in its size range currently available.  Battery compartments include Key Ring and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass. The pocket body with the optional cap can be used as a spare battery/storage compartment. There are black Anodized Aluminum or Brass bodies that use two AAA batteries. Stainless Steel and limited runs of Titanium are available with a single AA battery in the key ring style. The black Anodized Aluminum two AAA battery style with a momentary tail switch and pocket clip makes for a very powerful one-handed industrial inspection light. The PACIFIC can use Alkaline, Lithium or NiMH rechargeable batteries in AA, AAA or 3-volt CR-2 sizes.  An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
KINO BAY:  The Kino Bay is a high performance LED flashlight using a single AA battery and a 3-watt LED.  The head design incorporates a 17 mm diameter reflector and an unbreakable window to protect the LED.  The Kino Bay in Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass. The Kino Bay uses Alkaline, Lithium or NiMH rechargeable batteries.
The KINO BAY now uses the same electronics as the BALTIC SEA and the PACIFIC for greater battery efficiency and a choice of output levels from 50 to 600 candlepower.  At 50 candlepower output and a premium Alkaline battery rated at 3350 mA hours, the KINO BAY will maintain that output of 50 candlepower for over 45 hours before starting a slow constant decrease in output till 70 plus total hours. The pocket body with the optional cap can be used as a spare battery/storage compartment. The KINO BAY with a 10-year AA lithium battery in Stainless Steel makes for a great long term store and forget, emergency light for home or car at any power output level.  The Kino Bay uses Alkaline, Lithium or NiMH rechargeable AA sized batteries. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
GLACIER BAY:  The Glacier Bay is a one watt output high performance LED flashlight using a single CR-123A Lithium battery, a 3 watt LED, and a constant current power supply.  The Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass.  The Pocket style battery compartment is available in black Anodized Aluminum and Brass. The pocket body with the optional cap can be used as a spare battery/storage compartment. A double-ended CR-123A battery compartment in anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap. An optional 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. The head design uses a 17 mm diameter reflector with an unbreakable window to protect the LED. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
ATLANTIC:   The Atlantic is a one watt output high performance LED flashlight using a single CR-123A Lithium battery, a 3 watt LED, and a constant current power supply. The head design uses a 20 mm diameter reflector for maximum light output with an unbreakable window to protect the LED.  The Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass.  The Pocket style battery compartment is available in black Anodized Aluminum and Brass. The pocket body with the optional cap can be used as a spare battery/storage compartment. An optional 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. An optional detachable light wand in three different colors is available. A double-ended CR-123A battery compartment in an anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap.  The Atlantic uses a 3-volt Lithium battery or Alkaline, Lithium or NiMH rechargeable AA sized batteries.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
CARIBBEAN:  The Caribbean is a one and one-half watt output high performance LED flashlight using a single CR-123A Lithium battery, a 3 watt LED, and a constant current power supply.  The Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, Gold plated brass and limited runs of Titanium.  The Pocket style battery compartment is available in black Anodized Aluminum and Brass. The pocket body with the optional cap can be used as a spare battery/storage compartment. The head design uses a 17 mm diameter reflector with an unbreakable window to protect the LED.
The CARIBBEAN in the pocket style body is the smallest quality high performance pocket LED flashlight on the market.  One reviewer stated that it was the best pocket flashlight out of all the flashlights he had reviewed.  It is a perfect balance of small size and bright output and good battery life. It has also been described by some as a “POCKET ROCKET”.  The Caribbean uses a 3-volt Lithium battery. An optional 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. A double-ended CR-123A battery compartment in an anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
MEDITERRANEAN:  The Mediterranean is a two watt output high performance LED flashlight using a single CR-123A Lithium battery, a 3 watt LED, and a constant current power supply. The head design uses a 20 mm diameter reflector for maximum light output with an unbreakable window to protect the LED.  The Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass.  The Pocket style battery compartment is available in Anodized Aluminum and Brass. The pocket body with the optional cap can be used as a spare battery/storage compartment. An optional 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. An optional detachable light wand in three different colors is available. A double-ended CR-123A battery compartment in an anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap.  The Mediterranean uses a 3-volt Lithium battery or Alkaline, Lithium or NiMH rechargeable AA sized batteries.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
VOLCANO SERIES
RAINIER:   The Rainier is a three and one-half watt output high performance LED flashlight using a single protected RCR-123A rechargeable Lithium-Ion battery. The head design uses a 20 mm diameter reflector for maximum light output with an unbreakable window to protect the LED.  The Key Ring style battery compartment is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass.  The pocket style battery compartment is available in black Anodized Aluminum and Brass. The pocket body with the optional cap can be used as a spare battery/storage compartment.
The Rainier is the most powerful rechargeable single battery pocket sized LED flashlight available. Using the RCR-123 Lithium-Ion 3.7 volt battery, it will light up the side of a house at 300 feet.  Many have referred to it as holding sun light in the palm of your hand.  The RCR-123 Lithium-Ion battery under normal operating conditions can be recharged over 500 times with a normal run time of about 45 minutes per full charge.  Extra Lithium-Ion batteries may be charged and replaced as needed, and then the discharged batteries can be placed in the optional charger.  Some other competitive rechargeable LED flashlights require that the entire flashlight be placed in the charger.  While their flashlight is being charged, it is not available to be used.  The standard battery charger from Peak LED Solutions can charge two Lithium-Ion batteries from U.S. standard 120-volt AC outlet or a 12-volt DC automotive outlet.  The Rainier may also use a standard 3-volt Lithium battery for reduced light output and with a run time of about 12 hours or the 2 x AA battery compartment. A 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. An optional detachable light wand in three different colors is available. A double-ended CR-123A battery compartment in an anodized aluminum or brass is also available that can use a different head on each end, or one end can be used as a sealed spare battery/storage compartment with an optional cap.  The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
MAUNA LOA:  The Mauna Loa is a five-watt output high performance LED flashlight using two CR-123A Lithium batteries or a single 17670 or 18650 Lithium-Ion rechargeable battery, a 5 watt LED, and a constant current power supply.  The head design uses a 20 mm diameter reflector for maximum light output with an unbreakable window to protect the LED.  The head has a deep spiral groove for heat dissipation and a hex anti-roll feature.  Light output is from 100 to 120 Lumens with a maximum 6-volt battery supply.  The Key Ring style battery compartment is available in black Anodized Aluminum. A momentary push-button tail switch is an option.  (See First Responder for additional options).
VESUVIUS: The Vesuvius is a high performance ½ to 9-watt adjustable output flashlight with three Seoul P4 LEDs.  It can use two CR-123A Lithium batteries or two RCR123 Lithium-Ion batteries, a single 17670 Lithium-Ion, or a single 18650 Lithium-Ion rechargeable battery.  The infinitely adjustable output range is from a low of 25 Lumens to a maximum of over 400 Lumens depending on the type of battery set installed.  At the minimum output of 25 Lumens, the Vesuvius will maintain that output level for over 17 hours or 300 Lumens for 60 minutes, (90 minutes total), with two CR-123A batteries.  The Key Ring style battery compartment is available in black Anodized Aluminum.   A momentary push-button tail switch is an option.  (See First Responder for additional options).
FIRST RESPONDER 3 LED 9 WATT LAW ENFORCEMENT SPECIAL: The First Responder is a high performance ½ to 9-watt adjustable output flashlight with three Seoul P4 LEDs.  With the optional Compact Battery Compartment it can use two CR-123A Lithium batteries or two RCR123 Lithium-Ion batteries, a single 17670 Lithium-Ion, or a single 18650 Lithium-Ion rechargeable battery.  The compact Key Ring style battery compartment is available in black Anodized Aluminum.   A momentary push-button tail switch is an option.
The standard Combat Battery Compartment uses the same batteries as the compact compartment but can also use any two AA size batteries without modification, and with an optional AA battery tube extender any three AA batteries.  The ability to use standard AA batteries during emergencies such as Katrina or other disaster situations can be a lifesaver.
 The infinitely adjustable output range is from a low of 25 Lumens to a maximum of over 400 Lumens depending on the type of battery set installed.  At the minimum output of 25 Lumens, the First Responder will maintain that output level for over 17 hours or 300 Lumens for 60 minutes, (90 minutes total), with two CR-123A batteries.
The modular design of the First Responder allows simple modifications to upgrade the light to the newest advanced LEDs when they are available.  This ensures that the First Responder is always as powerful as the latest flashlight without having to buy a new one.  If damaged during field operations any part of the First Responder may be replaced.  The window is a scratch resistant plastic, if damaged send us a self-addressed and stamped envelope, replacements are free.
Other options include weapons mounts for rifles, shotguns, and pistols.  Traffic directing cones in white, yellow or orange-red that snaps onto the window nut.  Bicycle handle bar mounts and helmet mounts with remote battery packs.  The First Responder is the only combat flashlight that can be tailored to your specific requirements.
NIGHT PATROL is a five-watt output high performance LED flashlight with a constant current power supply.  The optional Compact Battery Compartment can use two CR-123A Lithium batteries or a single 17670 or 18650 Lithium-Ion rechargeable battery.  .  The Key Ring style compact battery compartment is available in black Anodized Aluminum.  A momentary push-button tail switch is an option.
The standard Combat Battery Compartment uses the same batteries as the compact compartment, but can also use any two AA size batteries without modification, and with an optional AA battery tube extender any three AA batteries.  The ability to use standard AA batteries during emergencies such as Katrina or other disaster situations can be a lifesaver when normal support and communications break down.
The head design of the Night Patrol uses a 20 mm diameter reflector for maximum light output with an unbreakable window to protect the LED.  The head has a deep spiral groove for heat dissipation and a hex anti-roll feature.  Light output is from 100 to 120 Lumens with a maximum 6-volt battery supply
Peak LED Solutions    29834 N. Cave Creek #118-249   Cave Creek, Arizona 85331 USA
« Last Edit: September 14, 2007, 01:16:43 PM by arewethereyetdad »
