Author Topic: Five Mega 1D M@g85 with AW 17670 (new) High Current Cells  (Read 9355 times)
« on: May 29, 2007, 09:31:47 PM »
Got my AW high current 17670 cells in the mail today.
Five Mega 1D M@g85 running the WA1185 bulb with AW's 17670 (new) High Current Cells
NO double click needed... These batteries run the WA1185 on a single click.  (Only batterys that will do this)
1D Mag85
Brighter than the Rop LE (running 2 AW C cells) and the Mag11 (running 2 AW C cells) but not quite as bright as the FiveMega Mag85 (running 3 AW C cells).
Very impressive power for a 1D size light...
Pics to follow!
Offline jimjones3630
  • Better to light one light than curse the darkness!
Re: Five Mega 1D M@g85 with AW 17670 (new) High Current Cells
« Reply #1 on: October 02, 2007, 06:21:10 AM »
1D cutdowns are so handy. did yours need tribore to fit 3x17670?
I used a 1/2in drill to wack away 2 groves to fit 2x18650. plan to build it into M@g61
FS sf M3, emolis & A123s
Aspherical lens for incandescent flash lights
Offline Gunnerboy
« Reply #2 on: December 06, 2007, 03:47:13 AM »
My Mag1D w/1166 needed to be tri-bored to fit AW's 17670 cells.  Not quite as bright as the 1185, but equal to my Mag2C ROP HI with the same runtime.
Gary  8)
« Reply #3 on: December 06, 2007, 05:25:44 PM »
Mine was tri-bored but 1185 drains cells very quickly and dims. May be a good host for regulated Mag11 or that Secret Chinese bulb you got!
Offline Gunnerboy
« Reply #4 on: December 06, 2007, 06:04:17 PM »
Is that the same bulb that LuxLuthor did destructive testing on and it pulled 7.90A before blowing?  You'd have to use some big cells, or Emoli cells.  Too big for a 1D...
Please correct me if I'm thinking about the wrong bulb.
« Reply #5 on: December 06, 2007, 06:20:26 PM »
You are correct, my mistake... Too much for the 1D... wishfull thinking on my part! The WA11 that I use seems to be a good compromise.  May be good for 6 x 2/3 A though... Lots a Lumens.
I think I'm gonna send LL 2 x 1160 bulbs as those are not on the list; maybe the ROP low too...
Hotwire Guys need some Regulation!
Offline Gunnerboy
« Reply #6 on: December 06, 2007, 07:25:31 PM »
Thanks for offering him the 1160's for testing!  Mighty generous of you.  I don't have any of those, but am interested in learning where the ideal voltage setting is for that bulb using AW's upcoming D-driver.
G
Offline Gunnerboy
« Reply #7 on: March 30, 2008, 07:44:10 AM »
« Last Edit: April 25, 2008, 03:16:05 AM by Gunnerboy »
