Author Topic: Don't use magnets with li-ion cells! Dead-short danger!  (Read 39098 times)
Offline CY
Re: Don't use magnets with li-ion cells! Dead-short danger!
« Reply #45 on: September 10, 2007, 08:16:11 PM »
half watt, ya your solution will probably work... but why?
much simpler to place a drop of solder on board and be done.
Offline Thujone
« Reply #46 on: September 13, 2007, 02:58:25 PM »
Is there any reason not to solder onto the battery?  If you have a nice iron you are not going to significantly heat the battery.  You could just put a blob on there and flatten it before it completely cools.
Offline CY
« Reply #47 on: September 13, 2007, 04:30:59 PM »
if you do it all the time and have the correct soldering rig... then you probably will not damage cell.
best to contact weld cells, but not cost effective to spring for a contact welder.
it's amazing all the solutions posted to get around putting a dab of solder on board.  :BangHead:
Offline half-watt
« Reply #48 on: September 14, 2007, 09:48:20 PM »
a drop of solder on the board???   what board?   no board on these cells, just a flat metal positive end.
Offline Krelku
Flashlight
« Reply #49 on: December 13, 2007, 11:42:09 PM »
If you want some good articles on flashlights, check out this site on <a href="http://www.flashlightinformation.com">pelican flashlights</a>
Offline georgemaggos
  • Grateful <><
« Reply #50 on: January 05, 2009, 03:23:30 AM »
Wow,
 some scary photos of what can go wrong, but a lot of great info on how to do it / make it right! Thanks
 ~George
"The test of courage comes when we are in the minority.
The test of tolerance comes when we are in the majority. "
Offline TorchEnthusiast5000
  • Torches are my life
« Reply #51 on: January 17, 2009, 04:40:29 PM »
Now I realise that most of you seem to believe there is a danger with combining magnets with lithium-ion cells
HOWEVER
I have used the two, in conjunction, in MANY projects, and have not found myself in peril once.
I would, in fact, reccomend it to any budding amatuer flashlight modifier on these forums.
Just proceed with caution guys.
 :P 8)  :thumbup: :D :D
remember, a torch is only as dangerous as the battery used
Dragon, Ti, Dam,and Classic Chammies, Blk, Bare, & Brass LCs, Blk & Bare LHs, X990, Rayzorlite, The Torch, Mag85, MagGH24, SF C3, C2, 6P, G2, & Winelights, Peak Caribbean, Pacific, McKinnleys, + more , Exolion Ti, Orb Raw NS, SS Gatlight, Eternalights, Nuwai QIII, Inova X5THAs, X1, ARCs
Offline TorchMan
« Reply #52 on: August 03, 2010, 02:01:01 AM »
I take it this applies to using them in the light itself? I do use them to charge the batteries in the Orb Raw and Raw NS in the Nano chargers.
Incans: SF G2, Pelican M6 Lithium, SL TL-3, Mags, MinMags, Browning Thunder & Lightning Bugs, M*G74
Hybrid: SL TT 2L, SF A2
LED: SF U2, Inova T4, Gladius, HDS U60, SG 30 LED, Coast lights, 8 LED AAAs, VB-16 3W, CPF LE #13 VB-16, LionHeart, Orb RAW, LionCub, McLux PDIII, Chammie, TiChammie,RawNS
Offline Mayheyde
  • high power flashlight
    • LED Spot Light
« Reply #53 on: March 22, 2011, 05:27:27 AM »
Are you serious?we use mainly magnets with li-ion.Many people don't know this.If you ate right,they all suffer from it.It is a big event!
Offline rajeshrao
« Reply #54 on: April 09, 2011, 11:19:57 AM »
Thank you .I can't understand your inventions..................
                            :thumbup: :thumbdown: :'(
