Poll
is there anyone want to buy it?
yes
0 (0%)
no
0 (0%)
Total Members Voted: 0
Author Topic: Ultra cree led xml t6 flashlight lights New M6  (Read 7384 times)
Offline LilyGan
« on: July 18, 2013, 08:37:26 AM »
Hi ereryone!
Here I introduce our products to guys,hope you will like it,thanks!
http//www.supfire.en.alibaba.com
Product name New M6 Power battery 4 rechargeable lithium batteries 18650 or 8 *CR123A lithium battery
Case Material Aerospace grade aluminum 6061-T6 Spot diameter 1 m at the irradiation spot diameter of 15-20CM
Light Source import CREE XM-L three T6 lamp beads
 Oprating Voltage  3.7 Operating Current: 700MAH
Light modes 5 files dimming(high,medium low,strobe,SOS ) Brightness 2000lumens
Surface tradement hard anodized   Switch the former head push button switch
Size length 133mm     head diameter 59mm, tail diameter 55mm Product Package white box
 Features
Small, flexible and convenient
  Deasign
Modelling design is novel
The product description is as follows:
1,Base: U.S. imports CREE XM-L three T6 lamp beads, excellent brightness, maximum brightness can reach up to 6000 lumens, life expectancy of 100,000 hours.
2, the circuit: with anti-reverse, anti-release function:
Five  dimming: High - medium - Low - SOS -strobe.
Beam Brightness: 2000 lumens
Lighting time: 120 minutes
Minimum life time of 120 minutes for the highlight and low light 200 minutes, SOS strobe 300 minutes
3, Battery: Use 4 18650 rechargeable lithium battery.
4, material: The shell is made of the oxidation of AA Grade III hard tube, shell work to further improve the high strength and durable and will not leave scratches with a knife scraping to carry more convenient, do not have to worry about keys and other sharp objects scratch; head Department for the first attack, It can be used to self-defense in danger; perfect tail of the design can
be inverted, using Candlelight mode; tail of luminous plastic cap designed to facilitate the night search for power outage; copper circuit warehouse and barrel switch pressure ring design more conducive to heat dissipation and conductivity; good seal, good waterproof rainy normal use.
Offline LilyGan
Re: Ultra cree led xml t6 flashlight lights New M6--do you like
« Reply #1 on: July 19, 2013, 07:41:51 AM »
[yt=425,350]http://www.supfire.com[/yt]
Is there anyone like the product?our products have so many superiority.use lithium battery and waterproof ip67,camping,adevnture,climb and so on.
« Last Edit: July 19, 2013, 07:44:37 AM by LilyGan »
