Author Topic: Fire-Foxes IV (24-40-60 watt) HID For Sale Searchlight GROUP BUY FireFox IV 4  (Read 121601 times)
Offline Rogi
I'm in
please sign me up for one
Thank's Rogi
« Last Edit: March 06, 2013, 12:58:31 PM by Lips »
Offline andi25252
Hi Lips,
please add me for 1 FF4 on your list.
Regards and greetings from Ol` Germany
Andi
ps
will be my first HID to top my
2000+ Lumen LED Lights  :)
Offline snypr
ok, im down for one.......my FF3 is still brand new and in box with card and all....guess I am more of a collector than a user....
anywho, count me in for one....
Offline BVH
Power increased. 60W - this is not a joke ...
Can has sense to think of IMR?
Welcome fellows!
BVH did test on the FFIII
52 input watts and 41.86 watts at bulb ranging from 3.5 to 4 amps depending on voltage. 4 cells into that although you have heavier pull at startup.
FFIV will be more but I believe they have run test for quite a while now. You need quality cells though Panasonic, Sanyo etc.
Perhaps Bob will chime in on what he found during his test. ( I think he has a video of it? )
Single 18650 XML lights are hitting the battery with 3 amps...
I looked at all my Youtube Videos and unfortunately, my video was of the MagicFire Magic Scorpion, not the FF3.  But I don't have an Ammeter capable of measuring inrush current so I could not provide start-up Amps anyway.
Good to see JetSkiMark here.  Haven't "seen" you in ages, seems like.
« Last Edit: March 08, 2013, 04:13:53 PM by BVH »
WWII 60" Anti Aircraft Carbon Arc (Sold), Short Arcs: 1.6KW NightSun, 1KW Marconi, 1KW VSS-3a, .8KW TrakkaBeam, 600 Watt M-134 Gun Light, 300 Watt Locators, Megaray, 150 Watt Set Beam, 150 Watt Communicator, Maxabeam Gen3, Fritz HandSun, LarryK14@52V
Offline kashmir
Hi Lips,
    Sign me up also, thanks! Been watching this thread the last few days and can't resist anymore...
    kashmir
Don
Offline one2tim
Sign me up also, thanks :)
The FF3 have been a great experience.
Offline Darkgear
  • Tin Man
  • If I only had a brain...
    • Darkgear.com
I got batteries from Fasttech today. Thanks kiely23.  These things are short.  A hair under 65mm.  Fasttech has 3400 mAh protected cells that are 69.4mm too.  Those might fit and since they are protected they could be used for other things that do not have the protection circuit built in.
Randy
Offline BVH
Got mine from Fasttech yesterday.  So "got Batteries" but "Got No Flashlight"!
Offline snypr
Got my pany 3400s today too......work awesome in my FF3 (damn thing is crazy bright!!!)....cant wait for the FFIV to come out.....
« Last Edit: March 16, 2013, 02:11:09 AM by snypr »
2x Panasonic 3400mAH for $17.95  incl. shipping !
http://www.fasttech.com/products/0/10001980/1141100-panasonic-ncr18650b-rechargeable-3400mah-37v-18650
Yeah, thanks for that link, Kiely!   Got my Pannies too!
Ordered some from below. Never heard back from them...
http://www.bestvaping.net/panasonic-ncr18650b-3400mah-37v-liion-battery-with-button-top-without-pcb-p-844.html
on to Fasttech
Little Update:
Some type of extended run-time bolt on or screw on carry handle for Fire Foxes in sample stage and may come out at same time as Fire Foxes IV. Mounting to tripod etc. This would be an accessory.
Not saying it's for IV at the moment but for other three versions of the HID lights. Will do both 3s or 4s
Not an official update as to what it is exactly but something is coming... Haven't seen it. If I'm understanding this correctly you put extra batteries in handle for more run-time on say the FF III... I would guess it would be an extension tube with a handle on it... I'll try and get some updates...
Also I said 2 millimeters longer but it's 2 centimeters longer
This is not it but someone who saw it said the handle looked similar to a Jetbeam rrt 3 handle. I don't know if it's an extension tube or if it even looks remotely similar or what at this point...
« Last Edit: March 16, 2013, 09:00:04 AM by Lips »
Offline mhemling33
Could you add me to the list please  :D
also for the fastech batteries use coupon code BLF it drops it down to $17.05
« Last Edit: March 17, 2013, 02:13:40 AM by mhemling33 »
Offline BVH
Lips, are you saying that FF4 is nearly an inch longer than FF3?
Offline teej
Add me in too!
- Thanks!
- Teej
Offline wingsnoles
Add me Please! Thanks
